If you want to compare these lighting technologies:
Yes, correct, this is spread very nicely round a room. One 60w lamp can light an average bedroom nicely.normal bulb - 60W
Lumen output may be as per 60w tungsten filament, however, you need a lot more of these to light the same space as a 60w TF lamp. Typical wattage in a bedroom, 200w.Halogen - 50W
Yes, ok, a BC/ES CFL at 11 watts will kick out about the same lumens as a 60w TF lamp, and spread it around the room nicely. Typical wattage in a bedroom 11 watts.CFL - 11W
Now this bit, I really must contest. A 5w LED lamp will not illuminate a room in the same way as a 60w TF lamp. As with halogens, you need a lot more of these to light a room. Typical watts for a bedroom: 20-30 with current technology.LED - 5W
