D
davebgas
What controls do I need with a high efficiency boiler?
Good heating controls require a minimum of four things:
an electronic timer or programmer that allows separate switching of heating and hot water
a room thermostat
thermostatic radiator control valves (TRVs), and
separate thermostatic control on the hot water system
Additional controls that may be worth considering to get the very best from a central heating system include intelligent heating controls, a weather compensator, a boiler energy manager and full zone control.
These are all explained on our page about Modern Central Heating Controls.
taken from http://www.nef.org.uk/energysaving/boilers.htm
In all cases, check that your installer has recent qualifications in energy efficiency. Gas Safe Register or OFTEC can confirm this. If the installation is for an oil-fired boiler, an alternative would be to ask your installer if they hold a Certificate in Energy Efficiency for Domestic Heating or an equivalent qualification.
from
http://www.direct.gov.uk/en/HomeAndCommunity/Planning/BuildingRegulations/DG_10030520
Fooooook me I'm good......
Government says must hold the certificate......
Come on Goldberg......... argue that matey..... goverment says you must.... why would they say that if it wasnt MANDATORY....
[/quote]
