I am renovating our kitchen. The single oven is going to be relocated across the room from its present position beneath the hob. The hob will remain where it is on the cooker radial circuit.
There is a double 13 amp socket available at the other location. It is a pyrolitic oven with a total 3.5 Kw rating. Is this sufficient?
In addition I will be having a 1000w combination microwave along side the pyrolitic oven. The mw also has a 1500w grill.
1. Am I correct in asssuming that a twin 13 amp socket would be insufficient for these 2 units if they were both on at the same time?
2. If I only used the oven on this twin socket would that be appropriate?
3. Rather than have a new radial circuit all the way back to the CU, which is very difficult because of laminate flooring and the distance away, would a spur from another 13 amp socket in the kitchen be an acceptable method of supplying either the oven or the microwave?
4. There is a 13 amp socket on another ring circuit for the living room directly through a plasterboard wall behind the position for the oven and mw. Would it be acceptable to take a spur from here and connect to an FCU and socket to supply either the mw or oven?
5. If none of the above is suitable, what are the possible alternatives?
The 2 ring circuits and the existing cooker circuit, terminate in MCB 32G fuses.
Immediately next to these 3 fuses there is an 80A/30G RCD.
The main switch is 100A.
