I'm currently having a bungalow renovated and it's been noted that the water supply is coming into the property via a lead pipe. Although people say there isn't too much to worry about with lead pipes....whilst I have building works going on I may as well replace this pipe at this stage.
The pipe runs under a concreted driveway down to the water meter.
I understand the water board will only authorise the work once it is done and connect from the pavement to the mains.
What is the simplest way of digging up the lead pipe? (or if it can't be located can I leave it and just put a new pipe down)?
Would I be able to hire a disc cutter to cut through concrete max.4" deep (how difficult is it and how many blades would be required)?
Do I just follow the lead pipe entry into the bungalow up through the walls so as to keep holes to a minimum?
What type of water pipe is required....plastic? diameter?
What needs to be laid under / over the new pipe before block paving the driveway?
How can I be sure that the pipe connection from water meter to mains is lead free also?
Any advice to the above or anything I've not thought about would be appreciated. Thx Karen
