Type of radiators to pick?
4 Jan 2009
True North
I've worked out my ratings in BTU for the rooms i'm wanting to add radiators but am unsure which type to get, single panel single convector, double panel single convector or double panel double convector.Also what brands are good or bad.
These are all for a new extension with insulated walls and floor.I'll be fitting TRv's
Utility room i need a 600x600 or 600x700mm and the room is 3250 BTU
Upstairs extension needs 2 radiators one at each end 500x1200 or (500x1400 best) and the room is 11000 BTU.
The only problems with the 'centerbrand' rads is that the vent plug sometimes snap off if overtightened and it's difficult to add chemicals.
The myson brackets can be a bit of a pain.
Stelrads and Henrads are easy.
Hi, thanks for the replies, since reading these replies i got a price for some Quinn radiators, the 1400x500 single was just over 4000 BTU but the same size radiator from mr central heating was 6000 BTU, is there any reason for this and are quinn any good. I'll get a price for the ones you've suggested.
Bleeding nipples in those are mounted directly in the rad; nipple stuck or damaged = new rad, in stead of new bleeding nut. Had a client where I had to replace the whole rad that was only 4 years old because of this.
Ahh I see. Lets hope that doesn't happen to me!
When I bought it they said I could buy a 'compact radiator kit' with it which as far as I can tell adds a grill to the top part of the rad.
Is this purely asthetical or does it serve some purpose?
I IMHO I was really impressed with Wickes rads.
They have got new universal rads that are either round top or finned.
You just turn then upside down for choice. The top grill and side panels can be brought separately and fitted retrospectively, very neat. I'm sure the bleed valves where screw in nuts :lol:
Wickes has gone up in my opinion, as I believe it has been sorted out by Travis Perkins. :!:
