Replacing a tap insert
8 Sep 2007
Manchester
My son and let out a flat, which is managed by a local estate agent. We had a call to say that the bathroom sink hot tap 'wasn't working'; I went to have a look to see what that meant and found that the tap could :? be turned very slightly but only by applying A LOT of effort and then just a trickle of water came out.
Not being a plumber I instructed the agent to ask a plumber to look at it.
Anyway we recently got a copy of the bill for 'replacing a tap insert', for
£80 plus VAT; this seems excessive to me as I thought this was a
simple job with minimal parts costs.
But am I out of touch? What do you think?
Location is near Manchester.
Thanks in anticipation of your feedback.
maybe bit excessive for a daytime if thats when you asked him to call round.
but what ever time he came if it took 10 mins or 59 mins it's still an hour labour + parts + labour.
we would have charged £57 plus the cost of the cartridge around a fiver depending on the type. depends on wether the plumb had the right one in his van or had to go fetch it and return to fit.
you are not a plumber, that is the problem, you couldn't fix what you perceive as an easy job, so you have to pay the going rate.
PS you are right it is an easy job (but i have been doing it for 31years)
i ran out of diesel years ago in a works transit van ( i had just picked it up brand new 1hr before :oops: ) phoned one of the other guys who got me a gallon but the van wouldnt start so we had to phone the garage, £50 call out to bleed the diesel pump, 30 seconds work (plus his travel, paperwork PLI etc etc) but he knew what to do.
Kirkgas
If I was a plumber I probably wouldn't be asking questions like this
on a DIY site!
At the risk of being pedantic I did not actually state that I could not fix it.
I don't have a problem paying the 'going rate'; I just needed some
guidance on what the 'going rate' was. Like most people I do not like
being ripped of, so was just checking. :)
What`s the going rate for landlords :?: Rigsby`s or Rackmann`s :lol: :lol:
Surely, as it's a rented flat the agent/landlord would be responsible for the bill, so you wouldn't be ripped off.
If you are letting out property it would be wise to get a decent local guy on board for regular work and who is not going to charge this much. If you were a repeat customer I doubt you would have been charged much more than £40.
twgas
Oops! :oops:
The first line should of course have read ' My son and I let out.....'.
I remembered to use the spell check, forgot to use the 'sense check'!
Thanks to evryone who took the trouble to reply.
