Hello,
If you missed my last post then this is a new problem (the other one isnt sorted either).
My boiler was losing pressure, had heat exchanger and PRV replaced and still doing same thing. Still loses pressure in about two hours when turned off.
Today something new!! I pressurised the system, put the hot water on for 15 mins before i went to footy and then tried to get a shower. No hot water from taps. Boiler running and heating tank. I turned of water and turned on heating as a test. Boiler switched itself off and pump failed to kick in. Pipes started to make a light knocking sound. Heating out pipe red (and i mean red) hot. Went upstairs to check other rads amd only two were hot (both towel heaters) and when i say hot i mean nuclear! Am sat here now having turned it all off and am cold. What on earth is going on? My boiler is aoil fired combi, heatslave 15/19.
regards!
regards!
