I have a Dusk to Dawn lantern identical to the one in the following link
http://www.diy.com/diy/jsp/bq/nav.j...refview=search&ts=1259585740789&isSearch=true
The problem I have is when it gets to twilight and the lantern is suposed to switch on, the bulb lights up for a second and then goes out. If I wait until it`s a bit darker and shine a torch on the sensor I can hear a click, I assume this is the sensor turning the switch off, if I then move the torchlight away from the sensor the lantern then stays on and operates as normal until the following evening, whe i have to go through the whole process again. Is the sensor faulty? any ideas would be very helpfull.
