one problem with 4mm 32A radials is that they are fairly marginal design, any grouping factors, insulation etc is likely to push them over the edge into noncompliance.
You could use 6mm instead but even that may not be enough with high insulation levels and it will make termination a PITA and branching virtually impossible.
