No he won't.
How modestI just happen to have a 1st class in Mathematics and an MSc. in E-Learning
How modestI just happen to have a 1st class in Mathematics and an MSc. in E-Learning![]()
As a friend of mine who ran a building company found out when he had his guys do some work in his flat, and they cut through a pipe and watered the flat below.....most PLI won't pay out for jobs you do in your own home anyway..
It's already been done - read Schedule 2B.Anyway, maybe we should make a list of typical jobs that a DIYer can reasonably expect to do without having to shell out hundreds of pounds on equipment and literature and passing exams.
Op, if you can find a local electrician who is willing to allow you to run cables as part of the design and install process subject to his specifications, then money can be saved this way.
I did it myself, the electrician was able to check cable runs visually, and he made the final connections, tested and signed it off. I was merely acting as his cable monkey, which saved me paying for his valuable time in this regard.
