- Joined
- 15 Nov 2005
- Messages
- 132
- Reaction score
- 1
- Country
Hi folks
I'm considering adding some sockets to a room (or two) in my house.
Basically, my master bedroom has got 2 single sockets which is useless when you consider the amount of appliances we have these days.
So, firstly, I suppose I should check that it's OK for a DIYer to add spurs to circuits providing I research the correct way to do it, use quality components, and run it in accordance with any regulations.
Next, I wondered how I might be best doing this. Our internal walls are plaster board but there's 2 external walls too. I'd rather not have to cut channels to run the cable to the sockets because of the mess to decor. However, the decor will need doing at some point anyway.
Is it possible to lower the cable from the loft down the cavity of the external wall until it meets the existing socket? I could then run the cable through the loft and down the internal wall to the location I need. This would be quite handy too because I want my sockets high up for the TV/DVD player. I guess there's a height limit in the regs too.
All I'm thinking is, if I were to hire an electrician then I'd expect them to do it without disturbing too much of the decor. But, I can't figure out how that might be done!
Any advice and help is greatly appreciated.
Rich
Rich
