Protection from Theft / Vandals
10 Oct 2009
West Midlands
i have recently replaced a gas feed to a boiler which is routed up from ground floor to first floor on the outside os a house. the original feed was ripped pout by tatters for the 2.5 meters of 22mm copper that would go a long way i am sure.
so this new pipe is less likely to be ripped out i have thought of fitting a u shaped steel capping over it but cannot source a product to do the job do you know of any thing that would do the job? i have thought of using denso over the feed to make it less desirable can you still get this ?
ta in advance
yes you can still get denso
you could advise to get it installed in M.I as it is only 2.5 m
Or you could encase it in some lead flashing. Then it's be safe from the gyppos :lol: :lol:
They do make a pvc capping, I've seen BT use it on telegraph poles that you could probably fit a pipe behind.
If you covered the whole pipe they couldnt see the copper :wink:
Could repost in electrics?
paint is an option similar to denso. Mi was considered but as i am not kitted out for it i went with Cu.
hiding the pipe wasnt the aim but putting a barrier that would take some Effort to get past was, i suspect plastic would give up its contents easily
Wrap it in lead :lol:
what's LSC ? scuse ignorance ta
use black mild steel pipe and saddle clips until you get into the building then go back into copper
Might require a bit of threading though depends if you are equipped with dies
Pipe saddle clips are not an acceptable means of fixing the pipe. :roll:
why cant you use saddle clips for MI pipe?, they are not allowed when fixing copper to cement/concrete but what is the issue with MI?
if you need an elbow -it will :idea: School Board clips
