i have recently replaced a gas feed to a boiler which is routed up from ground floor to first floor on the outside os a house. the original feed was ripped pout by tatters for the 2.5 meters of 22mm copper that would go a long way i am sure.
so this new pipe is less likely to be ripped out i have thought of fitting a u shaped steel capping over it but cannot source a product to do the job do you know of any thing that would do the job? i have thought of using denso over the feed to make it less desirable can you still get this ?
ta in advance
ta in advance
