Are you suggeting that the op looks closely at the fine printPrice can't include powerflush, theres no way they can do the boiler change / commission and powerflush properly in one day.
Has to have a minimum 2 year warranty, if the manufacturer also insists on a powerflush, that has to be included as well, as does any system upgrades.![]()
Perhaps BG are re-claiming the £400.00 scrappage scheme.
System upgrades like TRVs wont be fitted if the custard signs a disclaimer. Like they do with most warmfront jobs!Has to have a minimum 2 year warranty, if the manufacturer also insists on a powerflush, that has to be included as well, as does any system upgrades.![]()
I used to sub to BG & on installs they only gave me 2 to 3 hours to flush system & 5 hours for a straight heat only boiler swap. I work on my own & if I could get an 8am start then I was generally home by 2pm, first thing was to get the boiler on the wall & connect the circs then flush it while I was doing gas, flue etc, that way your doing 2 jobs at the same time.
You have to be running round opening/closing rads, reversing, draining etc! Its a very hands on job and takes several hours to do properly.
what boiler have you got now?
