First time here. Basically a house (1960's) I have brought I thought needed a new CU. As possibly thinking about renting out a room.. However the guy who came round has given me the following report:
• no RCD (earth trip protection)
• no main bond to water service
• main gas bond not connected to any form of earthing or MET
• no thermal protection to the imm heater
• dining room pendant has single insulation
• bathroom bond not to current standards
• electricity supply to barn not to current standards
• Main earth is undersized and the Ze (resistance to earth) is too high
• BS3036 rewireable fuses have the incorrect size fuse wire in them –
• The consumer unit has multiple circuits connected in to each fuse way
• Some inspected sockets need replacing
• The main earth has been cut out and disconnected
• Most circuits are wired in rubber insulated cables
• Lights and sockets in the lounge do not have earths
• Several sockets are reverse polarity
• Bathroom light fitting is not suitable for the location
• Consumer unit (fuse box) in bad condition – taped up
I pretty handy with DIY, but must admit I'm at a loss with the new Part P regulations, despite spending time on this site trying to glean on the legalities and certifications required..
I'd like to know what I can do myself and what 'has' to be done by a quailified sparky.
As mentioned I orignally wanted a new consumer unit installed, but the guy requested a complete rewire at about 4K.
Heres what I thought I could do myself:
1. Main bond to Gas and Water back to new CU
2. Replacement new Immersion heater (with thermal protection)
3. New dinning room Pendant
4. Inspect and replace Bathroom bonding
5. Remove lashed up connection to barn end-to-end (barn=shed)
6. rewirable fuses N/A will go with new CU
7. Multiple circuis N/A will go with new CU
8. No RDC N/A, will go with new CU (+ RCD)
9. Restore socket Polarity
10. Bathroom fitting replace with Zone 1 rated light
11. Rewire Lounge with proper spec cables ?
12. Replace all sockets
Heres what I assume will have to be done proffesionally:
1. Fit new CU
2. Main earth is undersized and the Ze (resistance to earth) is too high
3. Repair/replace - The main earth has been cut out and disconnected
Any insight on notifcations etc that I'd need to submit, areas I'm no loner allowed to touch etc would be gratefully recieved,
Many thanks in advance
1. Fit new CU
