I am putting a quote together for a new boiler install and the only way to run a pump overrun is to feed the cable from the airing cupboard, up into the loft and then drop down an external wall to connect into the PCB of the conventional boiler.
I am going to run it behind a soil pipe so it won't look too bad but I need to know if this cable needs to be UV resistant or protected in any way as it is going to be exposed to the elements.
Thanks in advance guys!
