Hi, I wonder if anyone can shed some light on my woodburning stove problem, I live in a large detached bungalow, which has a very good heating system with an 80,000btu gas boiler, but the price of gas, got me thinking about an alternative, which I went for a boiler that is supposed to heat nineteen radiators, there is only twelve in my property so I thought that will do, ( what will do a lot, will do a little) so It was fitted in the main lounge FEB: 2009 which by the way has three radiators in it, then the stove, which acts as a fourth radiator when the gas is on,so I thought that I would be able to turn them off, but over the last few months of cold weather, I have been using my gas boiler as the stove only heats the radiators in the lounge and the further away the rads, the cooler they get,I have contacted the manufacturer, who say's it sounds like I am not loading the fire properly, ( what rubbish) I have tried "LOGS" "HEATLOGS" "anthracite" "COAL" all which are dearer than gas, which is beating the object on saving, so I contacted the engineer who fitted the stove to my existing system,he came round, asked me to get a good fire, he had been in the attic before hand then I could hear the water boiling in the stove, and the overflow started to run,I told him he said it was OK, then what seemed to be a long time, as I was worried about the water comming from the overflow, he turned on the pump, after a few minutes most of the rads got very hot, so he left thinking he had cured the problem, but in half an hour of him leaving, all the rads went cool again, even with a roaring fire, Now I have spent a few thousand pounds on this prodject to give up now but it is very disappointing and frustrating, can anyone help me PLEASE, all I want is for the stove to do it's job, and by the way there are five settings on my gas boiler, but I only need to use the second setting to heat the bungalow.
Regards
pioner
Regards
pioner
