Replacing electric hob with a gas one
17 Dec 2004
Essex
I want to replace my cooker's electric hob with a gas one. I also have a twin electric oven underneath. There is one main cooker switch on the wall and it seems to power off both the ovens and hob when switched. All of this appears to be connected to a 30amp fuse in the main board.
I assume my new gas hob will need an electrical supply; I presume this is for the ignition button. :? What I want to know is, what should the hob be connected to and, with what type of cable?
I will be getting a Corgi registered gas-fitter in to connect the hob to the gas supply; would I be correct in saying that he should also know how to connect the electrics?
Thanks.
Yes.
Check the instructions for the hob, but it'll probably want a supply fused at 3A, and will only be designed to take a small-ish cable. The easiest thing would be to take the cable currently supplying the electric hob to an FCU with a 3A fuse and supply the hob from that.
It's Gas Safe now. Not being pedantic, but of you find someone flashing a Corgi card you've found someone who isn't actually registered.
Many registered gas fitters are also registered to do electrical work - check with them.
Most gas hobs come with pre-installed cable with a plug on the and, so you will only need a socket in the area.
