I've been doing some decorating and managed to get filler and emulsion paint on the sockets and light switches. Whats the best way to get them off. A mate suggested dabbing a cloth with spirit and wiping/scrubbing. Is that safe, is there a better way?
Just done the same thing. I used a sponge type sanding block gently, and then some white spirit.
If you are worried, turn off the electrics as I once got a belt when I was overenthusiastic with the spirit.
If it is a few little spots i just use a new stanley knife blade. They come off quite easily once they have gone hard and this method does not damage if done gently. How much is on them? If they are covered with the stuff and they are basic white ones maybe it is worth replacing them as part of the make over of the room.
emulsion paint will soften with methylated sprit. To prevent it running off and evaporating, mix it with washing-up liquid.
Abrasives will mark the finish of the accessories.
if you are competent to remove switches and sockets and re-fit them correctly, you can put them through the dishwasher or give them a hot hand wash and scrub (it really does work)
On the switches and sockets I have dismantled all the metal parts are brass (sometimes nickel plated) except for a stainless-steel spring for the switch click detent, and they are quite happy to be washed.
I am aware some some cheaper brands use galvanised steel for some parts.
At one place I worked at we used to repair PCB's for TV sets. When we got one in that was covered in carp we used a sink full of hotwater and plenty of detergent and a paintbrush to remove the gunk. Then 1/2 an hour under a heat lamp to dry it out. Came up like new.
I've had to replace loads of brass switches over the years where the X has gone through the laquer on the switch and the brass has tarnished as a result.
For small amounts of mess (splatters) I find repeated scraping with a finger nail works a treat - its softer than the plastic so you can give it some welly. If you've been really messy you'll have to resort to the methods above (not sure about the dishwasher though!)
