wiring switch
  • Thread starter Thread starter greeny4
  • Start date Start date
no mate nothing happens
that simply cannot be true...
you said...
When the left switch is off the right turns the hallway on/off. With the left switch on the right turns the hallway and kitchen on/off
so with the left OFF the and the right ON, the hallway light is ON
with the left ON and the right ON, the hallway light is ON and kitchen light is ON
ergo with the right switch ON, turning te left one on and off WILL turn the kitchen light on and off... it simply HAS to...
Just seen the switch is upside down. When turned the right way-
when the left switch is off no lights are on and the right switch doesnt work on on or off.
when the left switch is on the hallway lights come on with the right switch on on and and when the right switch is off both the kitchen and hallway are on
im not clever at reading and understanding so i need someone to tell me what wires to put where
how far's lincolnshire from me? I can be there inthe morning if you pay for a full tank of petrol...:)
i dont expect anyone to drive to mine just need an idea how to wire the switch
Normally it can be solved
However, to me it seems It unclear what you have.
Do you have a digital camera
i do but its hard to get a decent picture, it cant be any clearer than the last drawing i did of the 3 switches
ive been on this forum all day and still no answer just to wire a switch, looks like ill have to get a sparky
if you did as you were asked by me and got us the photo's we needed we might have a better chance..
simply drawing a box with 2x T+E and 2X singles into it doesn't help anyone at all..
your descriptions aren't the clearest either..
you also say that the other switches are right yet it's not worked right since you've been there..
for all we know it can't be solved because there is no live feed for the kitchen lights only the 2 strappers from the 2 way..
If it has never worked, maybe it cant work, maybe a numpty put the cables in and hasnt put enough cables in. If you are not very clever then why not read through the wiki page of electrics, you can start learning and understanding how one way switches work, then progress on to other types of switching and how they work, and with a multimeter it can be sorted, any of the sparks ect on here could sort out your problem with a multimeter IF it can be fixed.
just rang who i brought the house off said all the electrics worked fine till he changed a few switches, namely the one im trying to change. I can get a mutimeter from work, what do you need to know for me to sort this is it just the live feed
