Brethren,
Now that the weather is warmer and the central heating is no longer activating the boiler I have lost my hot water.
The thermostat on the hot water cylinder clicks if I turn it right down so I assume that is working, the timer on the programmer is active for hot water, in fact the 2-port motorised valve is definitely opening because if I force on the central heating then I eventually get hot water. That's not ideal though in this warm weather!
The only thing missing that I can determine is that the central programmer does not request the boiler to fire up.
I'm not experienced in the wiring output layout from the central programmer but I know my way round a multimeter so can do some pin-out checks if necessary if advised. The programmer is a Honeywell, details of which are at home. It has a separate twice/once/continuous/off option for heating and hot water. I tried resetting the programmer with the pinhole switch but this hasn't fixed the problem.
Any suggestions?
thanks
Any suggestions?
thanks
