Hi guys, sorry if this has been covered elsewhere.
My existing (20+ yrs old!) vaillant boiler gave out and needed replacing last week. I am a new landlord and have tenants in the flat so needed to get it replaced asap, and I didn't have time to get multiple quotes. The leasing agents sent their plumber round and the boiler was replaced within a couple of days - so tenants are happy. I just wanted to check that the work is priced fairly?
This is the work done (quote from the invoice):
"To remove existing boiler supply & install thermostatic radiator valves where necessary one room thermostat and one vaillant 24KW (ecoTec 24) condensing boiler, inline lime beater and magner clean use of all necessary pipe work and fittings to carry out complete installation. Also chemically powerflush heating system then dose system with correct amount of corrosion inhibitor." Only thing this doesn't say is that they had to brick up the old flue hole in the outside wall, as it was bigger than new flue. Not a big job, by their own admission. Also, it's a small flat (1.5 bedrooms, 1 bathroom, 1 lounge, small kitchen - 6 rads - 1st floor, London)
The price - £2,200 + VAT. I didn't know either way and just needed to okay the work urgently, but then I did a quick check and saw that the boiler is around £750-£850 (inc VAT) (Lower price for boiler only, higher for flue kit + timer package). If I assume another £200 for parts, then it leaves nearly £1,200 in labour. Is that fair?
Many thanks in advance for your feedback guys.
