The REAL problem with the economy.
I'm not doing anything that you suggest.
you clearly stated the 'Benefit Class' are vermin. Live with it. I'll remind you occasionally.
They are, i am not denying that. You are claiming I would treat family different. I have never said I would...
Are you retracting that now?
Ok shifty and skitzee,
Help me to get into work,
I have criminal records, unclean drivers license just bear that in mind.
So hang on, skitzee are you calling me vermin? I'd like to see you say that to my face...really, I'm sure your balls would be hidden behind your skirt in that instance.
So it seems it's really easy thesedays to change class, just apply for jsa, you also get the added benefit of knowing your vermin.
Do you not know that some people like myself have genuine reason for claiming jsa, and I am not happy on it, nor am I happy NOT working
I want to work, and do so, as soon as I get an opportunity.
Well the classic way is to find a grave of someone the same age and sex as you whos died, and get a copy of the birth certificate. This is where Facebook helps. They set up memorial pages to dead people o nfacebook with plenty of information to anable you to apply for a birth certificate. Then you need to get a passport with the birth certificate, and then a bank account with the passport. And you're away. Invent an uncheckable CV, and with a bit of luck your new employers will locate the correct NI number for your new ID.
Piece of cake........
OK you want to misquote people? Go back a couple of posts and find what I said, if your conscience isn't clear
You said the 'Benefit Class' are vermin. so that will include any members of your family should they claim benefits?
So tell them now, before it happens. They will become vermin in your eyes.
What you need is another clean ID....you need to do a Jason Bourne
I am thiking about that already, and it has already been planned, when I go back to bangladesh, I will come back with someone elses ID, but that's next year. The only problem I am facing is my property ownership.
Problem with that opposed to my plan is that thier are dead, and it will be on NI records
Ok...you have a record...you have points on your license...your a creationalist muslim... Anyone got the Taliban's number?
Als, I know you have taken my comments as an attack on you, however I am not claiming you are 'benefit class'. Only YOU know how hard you are looking for work. As I have said before (like 3-4 times now), I have no problem with people getting a leg up when they need it, but it is when people live on it that I deem them to be 'benefits class'
You need to remove the asset off the grid. Ei sellup, transfer the funds to a credit card then get the money back in daily chunks from a cashpoint overseas. Ideally you need a platinum card. Dont remove more than £10k at a time or the Bank of England has to be informed. Alternatively, a Bankers Draft might work, but you'll have to smuggle it out somehow through one of the weaker parts of the Eu borders like French North Africa, remembering the magnetic ink shows up on xray.
Yes...ffs how many times do I need to say it, 'Benefits class' people are vermin...scum...****e..
benefits class being defined as anyone that LIVES on benefits.
Any family member of mine that lived on benefits would be vermin...just the same as if they were a NON family member, but if people(related or non related) need help because they are down on their luck for a bit, that to me is what the system is for and I wouldn't class anyone who needed temp. help as benefit class.
Skitzee2k wrote:
If they were benefit class, yes i would. Infact in extended family there is such an individual..who I reported to the authorities as she was claiming incapacity while working in a bar.
Let's be clear here, a lot of people need a leg up from time to time, this doesn't make you benefit class...it is if you make it a long term thing though.
