Hi there, I've recently fitted a tap (not the tap-kit way, full on plumbing solder-ring, double check valve etc, couldn't fit an isolator though as it was no room underneath bathroom sink)
Its working great (touch wood it will last)
used one of these outside
But because I used it the other way around (pipe going down out from wall, instead of up) the tap is sitting upside down when tightened
Can you get opposite wall plate elbows? I've tried using plastic spacers but they snapped when I tightened the tap. Perhaps sawing off a thread on the tap will work? Or have you any suggestions.
Thanks for any guidance
