Hi there,
My old man is currently fitting an electric cooker (belling kensington 90e), and the problem is we are missing the wiring documentation. I'm fairly sure I know how to wire it up, but I thought I'd seek clarification from the experts first
The cooker is rated at 14KW. I've proposed he use 6mm cable, fed from a 40A wylex CU fuse with a cooker 40A disconnection switch on the wall near the cooker. The total cable length is around 5 meters, running up a concrete wall, under some uninsulated floorboards, then back down a wall in plastic trunking to the CU. What do you think?
Now, on to the actual wiring of the cooker. Taking the cover off, it looks fairly obvious. Three terminals paralleled with a busbar on the left (live), another three in the same configuration to the right(neutral), and far right is earth. Am I right, or?
Thanks for any input
