Well, well, well, Reidie hello again.
Have you given away your true identity for a second time?
When ever you find yourself in a tight spot you always return to the same line of intimidatory questioning, don't you remember?
You little rabble rouser you!
Wasn't it;
"do you think all those north sea oil rig workers can be wrong?" the first time a few years years ago?
Then it was;
"do you think this highly experienced aviation electrician can be wrong?"
But you were unaware that in both cases that their experience lay in industries that have a 'constant loop impedence', where as here on terra firma we have a 'constantly variable loop impedence'.
The only other people that you know are all ex-coal miners and the same is true of their experience, the loop impedence underground is also constant.
Therefore the straight answer to your question is:
Yes I certainly believe that you are all wrong because I know that none of you have any experience at all of electrical installation contracting.
Also given the fact that the double jeopary law has now been repealed, you and your friends may well also be once again be staring down the barrel of manslaughter charges!
Which would certainly go some way to explaining your less than democratic attitude to the thought of large numbers of electricians reading this book.
Well it's true what they say about a cornered animal being at its' most dangerous!
Happy reading everyone.
Regards,
Dave.
Wasn't it;
Then it was;
Regards,
Dave.
