if you ever had a cable go on a mega mixer mm21- mm22 or mm30 don't bother sending it off to refina or a repair shop its easy to do youself, take the handle apart then undo the cable by undoing the clamping bracket, then get a smaller screw driver and undo the 2 wires at the junction box then replace with appropriate cable keeping an eye that the cable do not interfere with the trigger switch, job done the whole process takes about 15 mins, better that being without your mixer for a few days.
I took the whole mixer apart once after being showed how to do it every single nut and bolt but i wouldent recommend that as i struggled to put it all back together, but the cable swap is so simple i thought i would show it it may save someone a bit of time and money
View media item 24266
