I am just about to start building my new house, starting with the (attached) garage. I would like people's opinion on what socket type to put in the garage.
The house will be built using ICF (insulated concrete formwork - like polystyrene lego with concrete in the middle). The inside of the garage will have plasterboard fixed on top of the polystyrene and then plywood up to a height of 1.2m to protect against knocks. As the plywood will cover from floor level to 1.2m, I would like to fix the sockets to the plywood. Rather than run the cables in conduit on the surface of the wall, I can easily run the cables in conduit in the polystyrene behind the plasterboard. (This is how it will be done in the rest of the house).
Given that I can bury the cables in the wall, am I better off going for a flush mounted box and a standard white plastic socket? If so, what sort of box should I go for? Should I just go for a standard dry-lining box and clamp it around the plywood rather than the plasterboard?
I like the robustness of metalclad sockets but I would need them with knockouts at the back of the backbox and as far as I can see only MK (expensive!) do them.
Anyone got any ideas?
