OK, Some for those with more experiance of fixtures and fittings
I have a large Koi pond, That uses a fair bit of electron juice. Its now also housing a lot of large and expensive Koi. All filter and heating systems on it are redundant and failsafe
BUT of course Its only as good as the electricity supply. Its currently on its own Separate circuit RCD and 16amp MCB. So it wont effect the house and the house wont effect it
As an alternative failsafe power supply I will use my Land Rover (Expedition discovery, with twin battery, large solar array and 2000 Watt invertor, 110 amp alternator) and several weeks idle time on a tank
Now the invertor has 2 x 13 amp square normal sockets and the pond currently has several spare 13 amp sockets in the filter house (Supplied by 6mm SWA and has its own DB)
How can I connect the 2 together without ending up with a widowmaker? I wouldnt be too worried with an extension lead with plugs at both ends cos I would Isolate both ends and connect before energising, but hate the idea of even having such a lead in case someone else plugs it in thinking its a normal extension. Cant really have the lead permanently connected to the pond either.
Can you guys think of a suitable method of doing this that will not result in a potentially dangerous live fitting if a family member connects this up without isolation
I'm also concerned, how I will guarantee they have switched off the pond at the main CU so that when the supply is restored it doesnt fry my invertor and Alternator
Any ideas?
Any ideas?
