On a combi, once the pressure has been released the system will usually vacuum enough to replace a rad valve. same theory as bung kits, if no air gets in, no water gets out.
So on a combi ,you need just to make sure all the bleed valves are off,or are you talking about another auto air vent and where would it be,then you can change the rad valves? thanks.
