,a kingsley tool was used along time ago on steam condense lines
well mr puller i like your new name,a kingsley tool was used along time ago on steam condense lines my own one is stepped 15/22/28.it is unsuitable for your idea of its application due to the profile of the nuts on modern compression fittings.![]()
delta t said:Sorry but I'm sure who mr puller is??
i've got one in the garage somewhere, if i get time/can be a***d i will see if i can find it and will post a pic
A drift is used to open the ends of tube to form a socket,a kingsley tool is a manipulative tool to form a ring in the tube to create a raised surface to form a seal against a fitting/valve.they were also used in high rise buildings on water services to prevent valves blowing off due to the pressure again i think the fittings were phased out in the early eighties![]()
go away puller your just a pest![]()
The chap i used to work with has recently had an operation on the tendons in his hand, he reckons it was years of kingley fittings.
