- Joined
- 29 Nov 2006
- Messages
- 26
- Reaction score
- 0
- Country
Have just moved into a new house. The kitchen has 10- 50W halogen down lighters fitted into the plaster board ceiling. Two weren't working when we arrived - so I had a look. The holder (push-in pin type) was corroded and the springs weren't holding the lamps firmly. So I went to an electrical shop and got two new lamp holders. I fitted these and everything was OK. Four weeks later they are corroded again and the protective insulation on the back of the lamp holder is falling off! None of the other 8 lamps are affected?! What the hell is happening? Can anyone help? I'm not sure if you can get a more heavy duty lamp holder - higher rating etc. What's even more confusing is that you may expect the ones over the hob or sink to be worse (damp areas) but it's not those ones. Thanks in advance.
