This port facing the camera is the cold supply of an ufh tempering valve I've fitted a few times. I think its Itailian. Rehau use the reliance valve afaik.
The design allows for quite an unrestricted flow.
Its quite constricted with about 1.5mm of clearance between the piston and valve seat when fully open where the arrow is pointing.
I didn't think this would work fitted across a low loss header. At the very best its bound to under perform imo.
Of course the OP's valve may be different but given what JG show in their schematic with a primary circulator and by-pass arrangement (looks to be in the wrong place) then I wouldn't deviate from that.
