I've read a number of posts some old and new but wanted to check my understanding is correct.
I have a small brick building attached to the house that is used for staorage ( a bit like an outhouse). It has a double socket already which is a spur taken from a socket in the adjoining hall. I am thinking of having some lighting to the building and perhaps an outside light added. But don't know how big of a job this is , before I get quotes of an electrician.
From what I have read is it viable to swap the double socket in the building (which is a spur from a ring) for a switched fcu which could power the lights in the builing and also then add a double socket to the switched fcu also? Could the outside lights also then be added to the switched fcu? or is this to much. From what I've read I thought so long as the first spur of a ring is an fcu then you can add to this .
