Do you mean that or do you mean 'every socket'.every plug in the room is fine
socket been working fine but now when i plug some thing in the neutral goes live changed socket but still goes live every plug in the room is fine just that one can some one HELP!!!!!
some full stops and commas might help.
Obvious answer is the neutral connection to the socket is no longer connecte to the neutral bar in the consumer unit. This strongly suggests a broken conductor in a cable feeding the socket or a loose terminal in another socket from which this socket is fed.
The apparent "live" on the neutral will be a voltage coming from the real live pin through the appliance plugged in.
when i test it with electic screwdriver and every soctet is fineHow are you establishing that the 'neutral goes live'?
