explain... what size cable and MCB?
How can I explain what I can't see ?
Suggested from OP:- 4 x socket off 1 x cable, new extension.
So it might be a circuit on it's own (lets hope it's not a 4 socket spur of a ring), in which case 20 amp MCB / rcbo and 2.5mm feed. Or it might be a 4mm radial 30 amp MCB / rcbo.
No one knows, the op doesn't seem to know- but my answer like the many others is a possible, all be it a guess due to lack of info / site view.
ok thanks for that, im not an electrician.
so you are saying that you can put 4 double sockets on a 2.5mm radial with a 20amp MCB/RCBO. makes sense i suppose as the cable is rated at around 27amps.
is there a limit to the number of sockets on this configuration?
