I've got an underfloor heating installation in a room in my house. In the recent cold weather, it hasn't been able to raise the temperature more than 15c above outside.
The room is about 30m^2 in area, and about 7m^2 does not have underfloor due to built in cabinets. It is an extension built in 2004, so modern insulation standards. It is quite exposed though - no rooms above/below it, and North/South/East sides are exposed. Only the west wall connects to the rest of the house. Also has four sets of French doors, which add up to 17m^2.
I see my choices as:
1) Increase the output of the UFH
- Replace carpet with a more conductive material e.g. laminate. I don't fancy this because it will ruin the feel of the room.
- Rip out floor and relay UFH with pipe centres @ 100mm instead of 200mm. Expensive, messy, etc.
2) Decrease the heat loss of the room
- The room should be fairly well insulated as it is built in 2004, I think the biggest improvement I could make would be the French doors switching to triple glazing. Potentially cheaper than ripping up the floor?
- I can't insulate the floor without ripping up the UFH.
- The walls/roof could be improved a bit but going from a U factor of 0.3 average to 0.2 won't be enough to make a difference to the room.
3) Add a secondary heat source
- It is a pain to get a radiator in due to the pipework in our system going nowhere near the room.
- At the moment I have a cheap electric convector in, but not a very satisfactory solution, and over the long run it is expensive.
Have I covered all the bases? Any suggestions on what would be the right thing to do?
