Hi there
I've had a new boiler installed and the electrician on the job noticed that the gas main wasn't earthed, which I paid him to do.
British Gas have since said that the earth wire should not have been attached to/run along the gas pipe. He said that according to current regs, there should be a 25mm gap between the gas pipe and the earth wire (because the earth wire has a current and may act as an ignition if there is a gas escape).
Also, BG said that the wire no longer needs to run all the way to the gas meter (as the electrician had done), but that it could be cut off at near the boiler (I didn't ask him how near unfortunately).
Can anyone verify this advice or recommend who I should contact to get a definitive answer?
Many thanks
lorry108
Many thanks
lorry108
