Hi Mikey, sorry to hear about the person you know problems surrounding the freezing of their unit.
Lucky I was passing because I'm one of the real experts on here who knows all about GS heating.
What you and your coleague need to do is to install another cylinder(heat bank) which will store previously heated water and keep it up to temp via a thermostatic three way valve.
So when the temperature next plumets to below zero the heat pump then takes the heat from the storage cylinder(heat bank) inside the property and then deposits it back into the ground thus preventing it freezing.
Don't worry about losing the heat because you are merely putting it back into the ground only for it to be re-collected at a later date once the temperature lifts to above zero again.
Look upon it as a heat bank (which is what it is).
GS is a very simple method of heating but you really need to know what you are doing with it (like I do), then once you do it's win win win all the way!
Good luck with your project and I hope this information is a big help to you.
Servotech
(Technical help at your service)
Servotech
