A 'collage' may be something that 'plumets'.
I find it hard to trust a self-proclaimed expert who is unable to spell.
I'd be more worried about employing someone who was so easily distracted from the task in hand by trivial issues...
one of my main concerns is freezing the ground as the person i purchased the heat pump from had just that happen to them thus they was forced to sell the pump, there ground collectors were in the front garden and during the cold spell at the beginning of the year they returned from holiday to find the water board diging the road up outside the front of there house, the pump had not only froze there garden and drive but also permutated out into the street and froze the main water pipes to the rest of the road!,
Interesting. They went on holiday, left the GSHP running and froze the water mains!
I wonder whether his PLI covered him for split water mains. Was it a DIY installation?
Are you covered for frost heave claims if your foundations, or a neighbours, are affected? Could be expensive.
.unless you think the installation will radically increase the resale value of the house
A DIY GSHP installation increase the value of the house? That is amusing.
servotit the ground will have frozen over a long period of time one cylinder of water wont defrost it or are you suggesting you use the heat pump to constantly fill the heat bank just so you can defrost the ground, What a great idea you could then install a gas condensing boiler to provide heating and hot water whilst using the heat pump to freeze and then defrost the ground as and when required simples!!!!.![]()
With a reserve buffer of energy the thermostatic valve senses the collector loop temp falling and now the buffer energy joins with the collector loop preventing freezing and extending the run time of the heat pump without depleting the natural ground energy unduly and then fully OFF for a period whilst the ground energy recovers.
If the heat pump has been extracting energy from the ground for a week at such a rate that it becomes frozen then quite simply the extraction rate EXCEEDS the supply rate.
The heat source is infinite, the problem is trying to extract too much from a small plot, instead of spreading it out, I said in an earlier post, you need an area twice the footprint of the property, or 2 or 3 bore holes, mats in the bottom of a lake is the perfect solution.
No heat store is going to heat a property for more than a couple of hours!
This is not true, properly installed it can heat the property 24/7
Any frozen ground is likely to need DAYs rather than hours to recover to above freezing when only heated from underneath.
If you get a Permafrost, the ground will never recover, at least for a few years anyway
Obviously when a professional system is so badly specified that it freezes the road as there is clearly a serious cowboy element at what SHOULD be the technically high end!
If it gets this bad you have a serious problem on you hands, including damage to any properties affected
Tony
Tony
