Texecom 48 install....East London
Yeah thats right, ComIP is only used for management of network purposes or diagnostics. Reason why I purchased it was for the wintex programming aspect then uploading the sofware. Havent got to that bit just yet.
Had a busy weekend in other DIY-ing bits and pieces but will get back to the Alarm aspect tomorrow.
Ive also ordered the Battery which I never had. Been reading the manual how to link out the Aux as Im not using it how do I actually do this, it doesnt tell me what wire to put were?
Hi Alarm
Sorry to bug you again about the linking out....still not sure exactly what to do
You say Into the two Aux terminals. Link it out...but how...what do I have to do e.g. do i put a resistor in there, or a wire and loop it? Sorry to be dump about this not familar with the terminology.
I got the battery yesterday and managed to sort that prob out as well as Zone out.
Having a look at the Aux tamper error by linking it out and also the RKP error that I was getting.
Yes wire link in each.
RKP tamper is going to be how its back tamper is fitting.
Hi Alarm,
Looks like post currently unavilable from yesterdays Q&A so didnt quite catch your responce.
Two questions:
1: How do I link out the Aux bit, do I loop a wire from one terminal to the other? Or do I put some sort of resistor in. Manual does really tell me HOW to do this.
2: For the moment I dont want to conenct the Bell for obvious reasons. How to I "pretend" to connect the bell to the control panel. Once the testing is finished I can then put the bell back on.
Another question that has sprung to mind is while looking at the control panel yesterday I saw another AUX 2 section next to the Zone inputs which has 4 terminals. Do I need to do anything with this?
Not sure whats happened there?
Yes use a loop/link in each AUX input.
Loop/link the 0v to Tamper on the bell connections.
Do the same, use a loop on the one above the bell connections.
NO!
You've mis-read the panel. That is AUX 12v
That is what powers your detectors etc. Putting a link in will short it out and at the very least blow one of the PCB fuses.
Thanks goot thing you told me about that.
Ok Ive managed to sort most of the panel out. Looped the AUX (near the bell), also wired a loop on the bell between 0v and Tamper.
Ran through the start up process and got most things working.
Now heres the difficult bit:
Ive got two error messages one which says ATS fault and the other Com 1 Fault which has the GSM module connected.
Ive managed to configure an IP address and got the panel on the network and started using WinTex. Problem I have is I dont understand Wintext thoroughly enough. I kind of set up the Zones and ares which I think are OK.
Walktest doesnt seem to be working properly and also the Wireless Expander isnt working at all. I do I get the wireless expander working? is there anything else I need to do?
Walk test, when in enginners do you ask an area to be tested?
Have you assigned zones to an area yet?
Thats probably your issue.
Expander: is it connected, is there power to it?
Did you have the panel search for all peripherals?
Keep going your not doing too badly :D
Wintex is probably one of the easier remote access bits of software out there. Your still not used to the terminology.
Your doing better than some so called "pro" engineers. So well done.
Hi Alarm
Thanks for your comments.
Havent had a chance to revist the Alarm since your last message. Had to finish of the painting in the Kitchen and Dining room area as this week its being fitted out.
Ok, I went back to the Alarm over the weekend and I have definatley assigned Zones and areas. All Zones 1-8 have been labelled i.e. Hallway, Lounge etc etc and then assigned to a Area A, B, C or D.
When I go through the Walk Test on the Panel, nothing is detected. Are the LEDs in the PIR sensors meant to be lighting up green and red....if so i dont get any lights whats so ever. Have I wiried them incorrectly?
Also still have problems with the Wireless Expander. I go to search mode and it starts seaching for 20seconds and comes back with nothing. The panel has detected it on port 3 as the first two are taken up by the Keypads?
Ive started using Wintex, it looks simple enough but how can I tell if things are right or wrong.
Network 3?
You sure?
Put all onto network 1 and see what happens.
Also check the numeric assignments.
PIR`s should light unless disabled, back to checking the wiring I suppose.
Hi Alarm
Looks like Im still having problems configuring the alarm.
I get a reading from the PIR but when I do the walk test, it says nothing detected. Ive taken some pictures below on how the wiring is
Also still cant seem to get the wirelss expander working, sorry previously I meant to say all on Network 1 but RKP 3 as the other two keypads have taken RKP1 and RKP2
Im trying to do most of the configuring using Wintex, as you said its so much easier
dont really know texecom detection equipment, where are your resistors, or does the dtec have them onboard?? (if you're using eol which i assume yoy are)
where is the power for the dtec??
ok just read the whole thread, on board eol :? sorry
still dont see any power tho??
