Hello,
I'm planning to get a new CU installed as my home currently has no RCD protection. It's a Wylex box where the old wire fuses have been replaced at some point with MCBs. I'm basically wondering how much additional work is likely to be required based on the following-
Firstly, inside the house the power circuits are all grey cable ring circuits with 4mm2 cores (red + black) of about dozen copper strands and solid earth, the sockets being surface mounted to the skirtings. Assuming it passes insulation/continuity tests etc, is that a case of recommended improvement that can wait until I redecorate each room, or something that an electrician would have to do as part of fitting a new CU?
Secondly, the ancient CU (also to be replaced) in the garage about twenty feet down the garden is fed by a ring circuit of solid core 2.5mm2 pvc cable, run in conduit under the paved path and patio. There's a lighting and power circuit in there, and the last owner used it as a workshop for many years running his power tools. Currently it comes off an MCB in the house, could it stay as is (assuming tests show the cable itself is sound) and go on an RCD protected circuit from the new house CU into a mini garage CU? Or would the electrician have to run an armoured cable in order to keep power in the garage? If so, are electricians typically willing to let the homeowner do the donkey work of laying the cable? Because that is going to be a quite extensive undertaking with all the paving.
Thank you for your time, any additional info that is required please ask.
