Hi guys, I wonder if anyone has any ideas on this. I'm insulating an internal wall with laminated plasterboard, using dot and dab. It's my first time using this technique. I stuck the first board up last night as a test. It seemed nice and solid, but this morning it's loose and obviously hasn't stuck. To be more accurate, the adhesive has stuck to the wall but not to the back of the board. Does anyone have any ideas why this would happen? It's standard adhesive as supplied with the boards (Gyproc dry wall adhesive). The boards are PB over 500mm Celotex with a final foil vapour barrier (so the adhesive is in contact with this foil barrier). Before starting I was sceptical that the glue would stick to foil , which is why I did the test, and it seems those fears have been borne out. Or is there something else I should be doing perhaps? Maybe paint PVA to the back of the boards first? Any advice gratefully received before I do the other boards.
