No, it does not.Hi, i have two tanks in my loft. the cold water tank and a small expansion tank. the small tank collects hot water when i have my central heating on
The small tank feeds you ch system, and the pumping over indicates the common back boiler problem: badly corroded and blocked.
bengasman, how would you solve this problem then? think i may have come across this yday, sent to re-commission a 552 (system was drained over winter) and when i switched heating on there seemed to be no circulation what so ever, (pump was fine) so i thought blockage
