Contacting EDF
How likely is it that a disconnection for non-payment of bills would be done by a physical removal of the supply which would cost thousands to restore?
It does seem very odd/unlikely - unless, perhaps, it was a last straw after a protracted period of non-payment. However, if that were the case, I would have thought they would have removed at least some of the installation within the house as well as cutting the supply outside.
Maybe they have just pulled the fuse (all the wiring of the installation still looks to be present) - which, of course, would be a good result for the OP.
Kind Regards, John.
Kind Regards, John.
This has been messing my head up quite a bit because to get a Court warrant to force entry into a domestic property, a bailiff has to stand infront of a Judge and ask for a warrant after explaining why. I work in many many different area's but under 3 different dno's and every judge i have ever known has refused a disconnect warrant for a domestic supply on non payment, they have always said "NO" and that is where you then ask for permision to fit a pre-payment meter which they almost always say "Yes" to.
I have just looked at my records for this year and i have done 49 disconnection in commercial propertys and 86 warrants in domestic, ALL of which, i fitted pre-payment meters to.
This is what I can't work out. Surely if the electricity co were owed enough money to warrant digging up the road to disconnect the power they would have that on record and want me to pay it when I phoned them up asking to be reconnected.
Wontdothatagain : There has been no forced entry into the property apart from me forcing the door to the outbuilding where the meters are. I'm now relieved to know that I'm not the only one who thinks it's odd.
I'm sure this is a very silly question, particularly occurring so late in the discussion, but can we take it that you are absolutely certain than the supply has been disconnected?!
Kind Regards, John.
Kind Regards, John.
I'm fairly sure. I've phoned up various electricity suppliers all of whom have told me that it's off. Also everything is turned on at the fuseboard but no sign of life at sockets or lighting circuits.
It gets curiouser and curiouser.
Interesting situation.
I think it unlikely the service cable has been cut outside (this is correctly termed a service removal) this UK power networks should be able to confirm as it should be recorded. Bear in mind that in such cases the DNO would require the supplier to cover the costs of the removal and normally the meter and cut-out would be recovered.
It is more likely the main fuse has been removed, this is what is termed a disconnection, unless you have evidence to the contrary.
In the first case it could be costly to re-instate the supply, in the second case very little.
My best advice is to ask the DNO to attend to confirm the exact position
That sounds fairly conclusive - but just thought I'd check!
It does. If they somehow managed to get access, the could have simply pulled their fuse - I think my money would be on that. Do you have any idea when the disconnection happened? Do you have any idea what route the supply would take to the propertyand (unlikely though it would seem that they would have done this) any sign of recent digging?!
Kind Regards, John.
On a debt disconnection visit, we always have a locksmith with us. I did 2 debt disconnections yesterday and the locksmith was in the property in under 1 minute on both. I then pull the fuse and seal up and we walk out closing the doors after us and no damage has accured and your locks are just the same. The bailiff HAS to put a notification through the letter box or leave it in the property explaining what has happened.
If the locksmith cant get in by picking the locks, he will then get the drill out and then leave a notice on the door explaining where the new keys can be picked up from or who to contact to have them delivered. Most locksmith have pre printed forms and tape them to the inside of a window close to the door we entered .
We also try to enter through the back door if we can as we don't want neighbours seing what we are doing and it is more likely that the owner/tenant enters through the front door and they will still have access.
Went and had a look today.
View media item 35230
This looks like the fuse to me. Also:
View media item 35231
This is switched off but I've been told that's irrelevant because the teleswitch only controls the supply to the night storage heaters.
I also had a look round to see if I could spot any signs of digging at the road side. Not a thing apart from some work which was obviously done by BT.
