hi, i have a honywells heating/water controller , and a gravity fed cylinder,
when i select heating, the heating comes on, when i select hw only the heating comes on but no hotwater and turning down at theremostat does nothing,
so i think its the acl mid position valve, the lever on the side is stuck at the bottom and cant move.
on the lifestyle wiring panel theres a fused switch (like a storage heater one) and when i switch this off the controller switches off, so i think thats the spur?? and the switch on the mpv does reset to middle.
i know this is what happend before and bgas changed it for this one .
the acculator does remove from body but i havent did it yet, as i dont know if the powers defo off, i cant see it connecting to main fuse box.
to test it manually is the lever ment to move freely ?
or do i take top of with power on and try move the valve head by hand?
will it move easily.
its a 679h340 30l0 22mm
