That sounds like the main switch. You can easily check if you have a multi-meter. If you're not sure, turn the main switch off.the only switch i see near the boiler is a fused one, but when i switch it off it switches the controls panel off
and the wires run to the junction box then 2 wires go down under ground.
So you have a sealed system boiler then; I thought you meant an open feed tank in the loft.the tank im on about is a small red one at boiler, a red one abt size of a football with a pressure gauge on it, i sometimes have to top this up as the system makes a noise if its below 1 bar
It will probably be easier to drain the system then. You only need to be below the valve.
You will need to add some inhibitor when you refill. You can get cartridges which can be injected via a radiator bleed screw. Do it, before you refill, at one of the upstairs rads as they will be empty.
The easiest way is with a multi-meter. But you have to test the whole circuit to make sure that the correct voltage is available to the motor.how do i test the motor in the mid valve in case its just that that's away
See How a mid-position valve works
