Need advice putting a raw plug back in
OM2
18 Jan 2007
I had a coat hanger in the wall
It's come off with the raw plugs
The holes seem to have plaster or concrete coming loose
I can feel this just tapping around the area
What do I do?
Should I just fill with a filler and then redrill the holes again?
I would suspect that this won't last very long and that the hole might now become a big chunk out of the wall
What should I do?
Any advice would be great
OM
Coats are heavy and the fittings require a good fixing. I assume the wall is brick - you want to redrill holes that go through the plaster and into the brick. Drill the hole deep enough to allow the whole of the plug to enter the brick, then using screws long enough to go through the fitting, plaster and deep into the plug, reattach the fitting to the wall.
thanks for the reply
so i should be too worried about bits of the wall seeming to be loose around the area?
thanks
another option if its just a bit loose
hammer another 1/4-1/2 off a plug [long strips]in the center to expand the plug enough to grip
but filling and moving a few inches is always the best option
i was thinking of just using a slightly bigger raw plug?
the very best method to overcome the problem of the loose plasplug (I bet you are not really using a Rawlplug) is this:
Drill the hole. Verify that it penetrates at least an inch into the brick or block (ignore any length that is in plaster). Verify that it is deep enough and wide enough to accept the plug and the screw.
Clean out all dust from the hole very thoroughly. A vacuum does a fair job, a squirt of water does an excellent job.
Push the nozzle of a tube of no-more-nails or similar deep into the hole, and inject it so the hole fills from the back as you withdraw the nozzle, leaving no air bubble
Push the plasplug in, adjusting so that it is aligned straight, and the end is slightly below the surface of the wall (you can put a screw a couple of turns ONLY into the plug to use as a handle
smooth off any excess adhesive with a wet finger, and press it flat
Leave it overnight to set
Drive in the screw. The no-more-nails will fill the space between the plug and the brickwork, and will transmit the expansive force to the brick. This will give you a very strong and firm fixing that will not turn, come loose, or fall out.
This method is fairly new and is not found in many DIY books or known by some older workmen.
john, that sounds awesome
plasplug?? whats that? never heard of it before
Rawlplug - aren't they all Rawlplugs? :)
EDIT: i was just about to send a picture of my 'Rawlplugs' when i noticed 'plasplugs' written on
is it ok to use a plasplug?
thanks
OM2 as I mentioned before, the art is ti ensure you are drilling into the brick (not mortar around the brick, or just into plaster !). Drilling the brick with the correct size hole for the rawl plug (just a brand name for these type of fixing) will give a solid fixing for a weighty coat hanger.
Now come on, and get the job done ;)
job done
i've made slightly bigger holes and have put in a bigger plasplug
ahem... erm... the previous one in there was about 3/4 of an inch :)
i don't think any brick was touched
i used the no nails and have left to dry over night
thanks for all the replies and the help
That is what I thought. You will not get any strength if the rawlplug is not into the brick. Mortar / plaster etc are too soft.
Glad to hear you have sorted it !
