What type of float/trowel?
23 Jul 2011
Belfast
Folks when applying a cement/lime/sand render to block wall what type of float/trowel do you recommend?
I have a few of the plastic (foam core) floats which have a slight rough surface, are these better that a steel trowel? Any advice gratefully received.
G
G
use a steel trowel to lay it on the wall and then use your float to rub up
