Blocking off light switch - adding switch to lamp holder...
8 Sep 2010
South West Wales
Hi all
For various reasons I might need to block of the light switch in a bedroom. I really don't want to have to move the switch, re-decorate, plaster, etc. if I can help it....
So I've been thinking of solutions and the best I could come up with was to change the lampholders to switched type - either an actual switch or pull cord. I was just wondering if it is ok to do this? I'm guessing the light switch will need to left permanently on so that I can use the lampholder switches to turn the lights on..... And as such, I guess electricity is permanently going from the switch to the lights.
So before I go ahead I just wanted to check this is ok and whether there is anything else I need to consider.
Cheers
Max
In what way do you mean 'block off' - put a wardrobe in front of it?
Yes, whatever you want as long as you do it properly.
Yes.
Yes, but that doesn't matter.
No. All you are doing is fitting an extra switch.
How many cables at the switch?
How many cables at the light?
Have you considered a separate pull switch?
Have you considered a remote controlled switch?
Can the switch be placed outside the room? (Obviously in most houses this could be very inconvenient.)
Hello
Huge thanks guys for the replies.... Much appreciated
That sort of thing. The room is being turning into a music studio and I need to apply acoustic treatment to the walls, including the area where the light switch is....
OK. Is there anything I need to know in order to do it properly? Is it a simple case of removing the old a attaching the new? Or is there more to consider?
___________________________________________________________________________________________________________
I should add her before answering the next questions that the room has two lights in it.
Just two - one red and one black.
At light #1: Four - one red, one brown, one blue, one black.
At light #2: Eight - three red, one brown, one blue, three black.
Do you mean near the door like you get in bathrooms? If so, no I haven't.... That would be an option. What would it involved from a wiring point of view? If it helps, there's a loft above the room and there is access to the loft....
With regard to pull switches, I had been considering these sorts of things:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270794480537
http://www.ebay.co.uk/itm/pull-swit...778209802&po=&ps=63&clkid=2267478236768984588
Are they any good? If so, are there better ones anyone would recommend? Can't seem to find too many on the net. Perhaps I'm not searching by the right terms.
Also, does anyone know whether there are problems with these devices if the cord gets close to or rests on the bulb?
No - wasn't sure such a thing exists! What would you recommend? Does it simply replace the existing switch and use the existing wiring?
Unfortunately not as there is another door on one side and a window on the other as you enter the room
Incidentally, now that I've looked at the wiring, I'd also be interested to hear what my options are for having separate switches for the two lights so that sometimes one can be on while the other's off.
Thanks a million for all the help.
Max
Well, with a loft above you CAN do whatever you want.
You will probably be able to disconnect the switch and pull the cable into the loft.
If you can, then tie a piece of cord on the wire before pulling up an then leave in place in case you want to put it back as it was sometime in the future.
If you can't pull it through then you will be able to disconnect it at the light - or you could do this anyway.
You can reconfigure the lights and switches in any way you want.
Have a look here for wiring diagrams -
http://www.diynot.com/forums/viewtopic.php?t=37582
P.S. your links didn't work.
Have seen your links. I suppose the pull-cords will be alright next to the lamp but I would not be keen on the string one. Can you have shades with those?
I would prefer separate switches which you could put in more convenient places.
